since switching the computers on my 87 sefi 302 when checking for codes with a scan tool what year is the ds9 computer from.it promts me to pick a year and if its an 302/302ho and i have to use mark vII as my car right
ds9 computer ?
1991 MK7 should work, I think the span for that ECM is 89-92?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
This is why I like to use ECMs from the same year car that I am doing the swap on. for example, my 89 CV got an ECM from 89 mark 7 when I did the HO conversion.
so when the scan tool asks for what year, you can say its an 89 (or what ever year the car and ECM are) you also want to to select the VIN code for an HO engine, which in most cases will be "E"2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
88-92 were all HO, E7 heads, 225 hp
86-87 LSC only was HO, E6 heads, 200hp.
84-85 were not HO, and they were CFI.
and its a D9S. If you get VSS related codes, and you have a funny bog off-idle, tie in the VSS signal and it should fix the issue. You'll need to add the pins to the ECM connector.86 Lincoln Town Car (Galactica).
yeah 88 according to this website. http://www.fordfuelinjection.com/?p=17~David~
oooh! I get it! It took me quite a while tho.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Well played from the maritimer.
Originally posted by rellik god View Poston the d9s does it have a year made? e9sf-12a6650-s1a,k9f07,sfi-sd3,x909x numbers on cpuOriginally posted by 87gtVIC View Postyeah 88 according to this website. http://www.fordfuelinjection.com/?p=17
Silly ford fuel injection.
Do they still have the Mark VII Mass Air Computer pin out too?
The D9S program code did exist in 88 tho, but no E9 part number on it. I had one in my Towncar at one point, and I had pulled it from an 88 Bill Blass. The other one you see sometimes is DX3. Not a bleeding clue what the difference is between the two, but it exists.86 Lincoln Town Car (Galactica).
d9s is tweecable i believe. my dx3 is notsigpic
