has anybody put a ratchet shifter in a box? I think that would be freaking awesome if you had a shift kit and a shifter and bark the ol' 1-2 all day
ratchet shifter - - anyone done it?
anything is possible, but please change the steering column if you install a floor shifter. i hate looking inside cars with a dead lever on the column and a floor shifter installed.86 Lincoln Town Car (Galactica).
yeah... its not like it hard to do in relation, lol
i like ratchet shitfters... 1st time i saw one i couldnt stop playin with itPete ::::>>> resident LED addict and CFI defector LED bulb replacements
i have a TCI street fighter for mine. I removed the colum shifter and all of the related parts.http://secondhandracing.com/Home.aspx
I like it when the automatic shifts at the right rpms on its own. My buddies column shift Duster upshifts at 6000 rpm under WOT. A fancy shifter does not really make the car any quicker than a tranny that shifts at the right rpms WOT. You might be able to lighten the governor to shift at the rpm you want.
I kind of like black&flames 5spd conversion. It still has the automatic column shifter and the t5 shifter. I converted a 4spd stick Monza to automatic but kept the clutch pedal. The clutch pedal needed to be depressed for the starter to turn. A few people that drove the car were confused by that.
Just my opinions. If you like the ratchet shifter, go for it.
Tom
i have to go with a console shift due to my exhaust. with the mid-legnth headers they would run right into the shifter linkage.http://secondhandracing.com/Home.aspx
mine will have it. I hate coloum shifters
but then, i've only ever owned manual vehicles, so with a manual valve body, it will be close enough to what i'm subconciously attuned withGMNRadio DJ, Podcast Co-Host
1984 Ford LTD Crown Victoria - Drag Car.
99 Ranger 2.5 - Parts hauler and Pit truck.
03 Mustang 3.8 Convertable - Head Gaskets fukered up
95 S10 93 Accord
Originally posted by TommyNI converted a 4spd stick Monza to automatic but kept the clutch pedal. The clutch pedal needed to be depressed for the starter to turn. A few people that drove the car were confused by that.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
My buddy had the starter on his truck wired to the wiper switch. Turn it to start the truck. I like column shifters. But I want a 5 speed so it will disapear one day.1989 Grand Marquis LS
Originally posted by 85crownHPP*Originally posted by TommyNI converted a 4spd stick Monza to automatic but kept the clutch pedal. The clutch pedal needed to be depressed for the starter to turn. A few people that drove the car were confused by that.
