ratchet shifter - - anyone done it?
    has anybody put a ratchet shifter in a box? I think that would be freaking awesome if you had a shift kit and a shifter and bark the ol' 1-2 all day
    anything is possible, but please change the steering column if you install a floor shifter. i hate looking inside cars with a dead lever on the column and a floor shifter installed.
      yeah... its not like it hard to do in relation, lol
      i like ratchet shitfters... 1st time i saw one i couldnt stop playin with it
        i have a TCI street fighter for mine. I removed the colum shifter and all of the related parts.
          When i get through this brake conversion and get some buckets in the Linc, I'm gonna do one
          '80 Town Coupé
            I like it when the automatic shifts at the right rpms on its own. My buddies column shift Duster upshifts at 6000 rpm under WOT. A fancy shifter does not really make the car any quicker than a tranny that shifts at the right rpms WOT. You might be able to lighten the governor to shift at the rpm you want.
            I kind of like black&flames 5spd conversion. It still has the automatic column shifter and the t5 shifter. I converted a 4spd stick Monza to automatic but kept the clutch pedal. The clutch pedal needed to be depressed for the starter to turn. A few people that drove the car were confused by that.
            Just my opinions. If you like the ratchet shifter, go for it.
            Tom
              i have to go with a console shift due to my exhaust. with the mid-legnth headers they would run right into the shifter linkage.
                mine will have it. I hate coloum shifters
                but then, i've only ever owned manual vehicles, so with a manual valve body, it will be close enough to what i'm subconciously attuned with
                GMNRadio DJ, Podcast Co-Host
                95 S10 93 Accord
                  thats even easier to do away with than the column shifter!!! splice 2 wires together....
                    My buddy had the starter on his truck wired to the wiper switch. Turn it to start the truck. I like column shifters. But I want a 5 speed so it will disapear one day.
                    1989 Grand Marquis LS
                      Sort of an antitheft device and pushing the pedal in was so simple, I did not change it.
