I posted this over at CVN, so I apologize if you had to read it twice, just wanted to see what the non-CVN people here thought. I got my Fel-pro intake gasket set and to my surprise it came with some really serious looking molded rubber end seals, complete with lips to keep them from sliding off the block. Wondered if they'd be any less likely to slip than regular style gaskets, or just using RTV.
End Seal Intake gaskets...
those end seals are decent......in your case, i would use those .......make sure to use silicone on the corners of those gaskets betw the intake gaskets and those end seals.....again those seals are decent, i've never had one of those slip out or leak
good luck!
scott
