How much does it cost to get these gears installed by a mechanic, or can i do it myself?
rear 3.73 gears
rear 3.73 gears
where r u located? i'll do it for $250-300 plus parts
scott
im in raleigh NC. $250? that much? it must be a difficult/time consuming job. I've FINALLY gotten around to starting my HO conversion i got the upper intake off today1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by 89LincolnTWNcarim in raleigh NC. $250? that much? it must be a difficult/time consuming job. I've FINALLY gotten around to starting my HO conversion i got the upper intake off todayhttp://secondhandracing.com/Home.aspx
Originally posted by mrlandyachtI had my whole rear end done one the car with 3.55 gears for about 1100 at a trans shop...
Total cost of my rear end rebuild was $400 for a new Detroit TrueTrac diff, all the rest was free, and did the install myself.
Originally posted by 89LincolnTWNcarim in raleigh NC. $250? that much? it must be a difficult/time consuming job. I've FINALLY gotten around to starting my HO conversion i got the upper intake off todayOriginally posted by GMGTyou mangwhore
resident sniper expert
1100? Wow. I had mine done at the dealer. Replaced everything, except axles, included a rebuilt Trak-loc, 3.73's, control arm bushings, and a brand new aluminum cover for $425...Builder/Owner of Badass Panther Wagons
yea that labor seems high, but i replace all the seals/bearings for that price.......the shop i worked at would charge 400-600 labor for that job........rear disc conversion is also easy at this stage
when I do mine, its gonna be a total rear overhaul as well. I think I have a tweaked axle anyway, so that will get changed out, all bearings, seals, trac-loc overhaul. Actually the only thing that won't get changed is the gears LOL.86 Lincoln Town Car (Galactica).
Originally posted by mrltd1100? Wow. I had mine done at the dealer. Replaced everything, except axles, included a rebuilt Trak-loc, 3.73's, control arm bushings, and a brand new aluminum cover for $425...
Not doubting your story, just wondering how I never get deals like that....FOR SALE: 89 Grand Marquis GS HO. Quarter mile = 15.8 @ 87mph -- pics http://public.fotki.com/vfr700f2/car...rcycl/mercury/
Junkyard HO, MSD wires, stock Mustang headers, off-road H, Hemi Super Turbos. 3.55 trac loc, HO governor and servo in stock rebuilt AOD. 3-row rad, air pump delete, cop rear bar, wagon rear springs, 93 CV rear discs, 98-02 Grand Marquis wheels, Class 3 hitch, aluminum space-saver spare.
Coming soon: 98-02 front brakes, cop springs, Monroe cop shocks, 96 Cobra wheels w/255/50/17. Better yet, need a nice wagon to put all that stuff in.
