coolant hoses to egr
    Anyone know offhand the ID and length of these? They look suspicious (I think they may be Muslim)
    1/4".......need about 2' of hose to play it safe.......do not hook them up to the egr spacer if you have a stock egr spacer bored out to 63mm
      why's that? I've had 'em hooked up with no problems or loss of coolant. I was going to bypass it anyway by connecting the two somehow (do they make adapters that I can stick between them for now?) but I guess when I've got the intake off I can just run the one new hose in place of the two.
        sometimes with the bored out spacer, it will leak coolant. When I first did the HO in my car, it was sucking coolant and I thought I had the head gasket on wrong because of the smell.
          ah, gotcha. thanks. I will examine it carefully when I pull it back off to yank the intake..goddamn rounded screws..
