removing plenum off '89 302
    Just a quick question,
    I want to change the passenger valve cover (posted this a few weeks ago) and I was told I have to remove the plenum (the curved thing, intake, or whatever its called). Before doing so, is the plenum filled with coolant? I see there's a soft plug in it...but I wasn't sure if there would be coolant since coolant (in my opinion) has no business in the plenum (no need for a water X-over there since it doesn't tie the cylinder heads together).
    But, I have been wrong in the past. And while we're on this subject, can someone please explain why there are 2 coolant lines (3/8") running to the throttle body? I thought they were VAC lines until I found a wonderful green surprise upon their removal... Why on earth would you ever want to heat up the air/fuel mixture with coolant lines?
    Thanks!
    Those coolant lines go to the EGR spacer. They are cooling the spacer, not heating the air up. Coolant flows in, through the spacer and then right out the other line. Coolant does not flow through the upper intake. Only the lower intake is "wet".
      Interesting about the EGR.
      That's what I figured concerning the upper intake. The freeze plug must be there for casting purposes.
      One more thing...any there any "common" problems with taking the upper intake off? I don't mind surprises, but would prefer without.
        Old vacuum hoses like to break. Be sure to have them all disconnected and have all of them reconnected and snuggly attached or you'll have vacuum leaks. While you got it all apart clean the intake and the throttle body and the iac. Just as preventative maintainence.
          I have worked on more foxes than panthers. I don't recall if the boxes have them, there may be an "anti shake" brace on the rear of the plenum. It must be removed, then there is another stud under it. Total of 6 fasteners to hold plenum to lower intake. There are 2 hiding under the 5.0 plate...
            I'll probably just replace the vacuum hoses to ensure they never break or crack in the near future.
            I have worked on more foxes than panthers. I don't recall if the boxes have them, there may be an "anti shake" brace on the rear of the plenum. It must be removed, then there is another stud under it. Total of 6 fasteners to hold plenum. To lower intake. There are 2 hiding under the 5.0 plate...
            Very good. I imagine I would have wasted about an hour trying to find those 2 bolts under the 5.0 cover too.
              replace the PCV stuff while you've got the upper intake off, it's nearly impossible with the intake still on. It's all located in the lower part of the manifold - pcv valve, pcv grommet, and pcv breather screen (in order of removal, the valve sits inside the grommet and the breather screen is underneath)
              the tiny vacuum hoses running to the solenoids on the upper intake are rotten cocksuckers. they break with the slightest amount of misplaced force, be really careful
                Is that what that is for? Boxes don't have them, but I've seen them on Mark VIIs. I always tossed it out.
                  anyone got pics?
                    its a U shaped steel bracket that goes from one of the rearmost upper intake bolts to one of the rearmost lower intake bolts. You have to pull the nuts off the studs, remove the bracket, then remove the bolt.
                      What's the point?
                        I have absolutely no idea. I secretly suspect it exists so people go "wtf is this?"
