I have a 83 gm and i have put a 94 5.0 out of a mustang (i posted before it was a 93 but have since figured out it was a 94 or 95) i am converting to carb i have edelbrock 1406 with a performer intake and hei style dizzy and aod trans out of 88gm
1. The center port on the back of the carb is for brake booster right? the port on the carb is plugged right now
2. i should be using the drivers side vacuum port for the hei dizzy?
3. the front pvc port goes where? i have a port on oil fill neck and one on edelbrock airfilter housing but no pvc valve?
4. the power for the dizzy needs to be hooked up where?
5. and can i hook the electric choke up to the same spot ?(see 4)
6. on my 94 heads there were holes for some of the egr crap i took off i bought plugs to plug them but they dont fit what size plugs should i be using?
7. do i need the sensor on the drivers side rear most port
8. do i even need the cfi computer anymore i have setup a new fuel control system using a relay and oil pressure cutoff switch if i need the computer which wires i just left the power hooked up i would really like to just pull it out of the car
Thank you
Thank you
