finally! its running normal...sorta
    Well i bought an 88 town car and have been doing some tlc to it the last few weeks. The previous owner put dexcool in the coolant ugh... So i have been in the process of flushing it out. This process has comprised of changing hoses, taking out the thermostat and flushing it water about a hundred times. So finally all the sludge has cleared out and the car is running at a steady cool temp without the thermostat. So now i will flush it another hundred times and put the thermostat back in to complete the job.
    I just wanted to share my happiness that i can now run it steady without it overheating. A lesson for all, never mix dexcool with regular coolant it will be the worst experience of your life!
    2002 Nissan Maxima 6spd 14.2@98mph "it may or may not be street legal"
    2009 Chevy HHR Panel - My office
    1988 Lincoln Town Car - The new love of my life
    Yup disastrosludge. Yay!
      keep an eye out for radiator and water pump leaks now that you flushed the sludge out.
      i'm not too far away from you if you need a good mechanic mang
        ew, Dexcool. Good to hear you got it back to life.
          x2 on the go see Scott if you need something. You're lucky to be as close as you are.
            x3. i wish i was closer.
            wonder why they thought it was a good idea to put 'deathcool' in it..
            1994 MGM GS Montigua
            2002 Mustang GT Coupe
              yeah deathcool is right, this is good that i have a guru near me, i might need to see him when it comes time to change my transmission.
                I think GM created dexcool to sell more cooling system service. Thanks, GM!
                Once that stuff turns into muddy water, you're lucky if it ever comes clean...
                  I had a 'no-getting-heat-inside-the-car' problem in my Impala. Figured it was a bad heater core.
                  Then I read about how much DexCool sucked. So I drained it all out and back-flushed the whole cooling system with pressurized air and fresh water. Made a mess. Replaced it with good old green stuff/water mix. No heat problem went away. GM lied about DexCool problem. It plugs shit up. 'Nuff said.
                  1988 Grand Marquis LS (White Lightning), 2003 Mercury Marauder (SOLD),1979 Mercury Cougar XR-7
                  http://landyachts.homestead.com/page5.html,1951 Merc on a '88 Lincoln Town Car Chassis:http://landyachts.homestead.com/index.html
