OK, exhaust time
    OK, exhaust time
    OK, I need to get exhaust. I failed emissions, and the cats are the problem. So, what fits nicely?
    I'll need to get an H/X-pipe with cats and I'll need a quiet exhaust. I'll be running 2.5" I saw something about s10 mid pipes??
    Oh, well off to install the rear.... :banana:
    move to NH, they only test emissions on 96-up. they're supposed to do visuals on older vehicles but alot of places don't. as long as its not leaking, you're good to go
    Save a seal, club a liberal.
      mike.....the mid pipes i've been using are a combination of 2.25" mustang flanges, and a set of s10 mid pipes (done 4 systems like this on boxes so far) the pipe # is napa 43-281............i can get pipes and flanges for around 60 bucks for both sides.............eric had an x pipe with cats, it is a tight fit but it works, he said problem is the pipe will need to come down if you need to remove the transmission pan.......btw the mustang h pipes fit perfectly................as for tails, you can use stock wagon tails (pricey at $60 ea...i priced em out for kevins wagon) or get some custom 2.25" tails bent up..............i plan on using lincoln motorsports in hammondton nj to bend up new tails for my lincoln (mine are 7 years old, and starting to go) and new tails for the vic and a custom exhaust for teh volvo
      good luck, and i got u a fuel rail mike
      scott
        cool. Only 2.25" though... Hmm. Might just get custom done again then. Definatley need 2.5 with the motor I'm gonna be running. Well, prolly not, but I like 2.5"
        The 3.73's and TL are in.
