My 89 Civilan car has got a slight hesitation when I just mash the gas a little bit. It also surges on idle when I crank it. It stops if I let it run for a minute or two. It'll still do it when its warmed up and I cut it off and crank back it'll idle up and down for a minute.
Sometimes the slight hesitation is not as bad as some times. Seems like it Varies from time to time. Plugs, wires, cap, rotary button is all good. Any thoughts on this to what I can check? Yes it is the 5.0L that is stock. Thaks guys
