Originally posted by porschpow
View Post
I should've elaborated, the firing order is dependent on the camshaft. The lopo cam has the firing order of 15426378, whereas the HO cam has the firing order of 13726548. Computers also play a role in this as our engines are fuel injected and the computer should be matched with the cam's firing order.
So no you can't just arrange the wires to that of a HO, not without at least changing the cam and computer. But it'll be underpowered without the proper heads and fuel injectors.
