You can run them with straight oil and let it knock and it will go a very long time. Ford smallblocks do not need oil pressure, they need oil flow. As long as its making at least enough to keep the red engine light of doom off when driving, it'll keep going. When the light is on all the time, its done.
overfilling fluids?
may be time for thicker oil... or a good degunking.
that would be my best bet... but there are other ways to do so. Others may have opinions on this subject. Though, I would definitely avoid any "engine flush" options as that's almost guaranteed to clog something up.
Yeah, that was why I was concerned about the auto RX stuff, thanks, this is for my dad 's 86 MGM"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
Originally posted by gadget73 View PostYou can run them with straight oil and let it knock and it will go a very long time. Ford smallblocks do not need oil pressure, they need oil flow. As long as its making at least enough to keep the red engine light of doom off when driving, it'll keep going. When the light is on all the time, its done.Builder/Owner of Badass Panther Wagons
Originally posted by mrltd View PostNot really true. The PO ran my 91 GM with the light on and making a hell of a racket for over a year, I bought the car and kept driving it for a few months, running it hard with the light on all the time. Even blasting down the highway. It'll keep going until it doesn't. I've seen them drive miles with cracked blocks, pistons blown into pieces...My other car went thousands of miles with an autometer ultralight mechanical gauge reading 0 at idle. The trans gave out before the motor.86 Lincoln Town Car (Galactica).
so, on an off topic, what makes these motors knock? Is it year specific?"To Find yourself, you must first lose yourself"
the firing order is a little rougher on the rod bearings than the HO firing order IIRC. it's basically the rod bearings getting worn. Even with a spun bearing, they'll continue to run good (knocking all the way) for some time.
Originally posted by gadget73 View Postdidn't mean to imply that it blows up when it gets to that point, but thats the point where you can honestly say the engine is very well worn and it might be a good idea to consider doing something about it. The 302 is a tough motor, but it does eventually reach a point where it says FU. Losing the oil pump is generally that point.Builder/Owner of Badass Panther Wagons
so on a stock Lincoln can i arrang ethe plugs in an HO firing order without any conseguences and repurcussions?"To Find yourself, you must first lose yourself"
