Hello,
I am changing the oil pan gasket on a 1989 MGM. The reason is leakage. Yes it is a very wonderful and fun job. No I did not remove engine, way over my head.
On this project I am asking for knowledge and tips on how to do the best job possible. I typically take pictures, clean as many places as can be reached, and consider doing extra. So I would appreciate any ideas on areas to inspect while under the car.
Pictures will come tomorrow.
Details
1989 Mercury Grand Marquis
Mileage: 52,000 (7,000 in last 16 months)
Maintenance History
Work orders show it was care for relatively well. Driven in southern California. Engine was serviced in January, THANKS to all who helped. Replaced: vacuum hoses, valve cover gaskets, major tune up, lots of cleaning.
Issues
A) Oil is leaking from passenger side of oil pan and along the rear. Oil has covered the surfaces behind the pan and left marks on asphalt. Gasket was not seated properly; over tightening of bolts may have been the cause.
B) There are oil stains above the pan between the oil pump and cylinder 1.
Found So Far
1) The gasket just removed is rubber, cracks 1/3-1/2 of the way around steel inlays, cracks are towards the outside edge
2) The gasket has two non-smooth, bumpy areas. They are at one end of the gasket, on one face, mirror images, just before the corners. The marks run from one edge to the other. I want to say it looks like a seam but that would make no sense.
Resources
I have both the Shop and Electrical-Vacuum manuals
What I Am Thinking
1) Saturday I will clean everywhere covered in oil and other areas I can reach. Look for signs of potential problems. Sunday I will reassemble everything.
2) The water pump and timing chain will be inspected. There have been times where the engine ran hot. My heater electrical/vacuum switch is not functioning, AC just went.
3) With so little space between pan and block I plan to use brake cleaner and rags. The new gasket is FEL-PRO, OS 34508 R.
4) Would like to check suspension, not sure how.
If there are specific pictures needed let me know.
Thank you,
Ringting
Details
Maintenance History
Issues
Found So Far
Resources
What I Am Thinking
Thank you,
Ringting
