No second gear???
    No second gear???
    Is there a way with the AOD to select second gear?(shift kit??) I will be towing a trailer and having control of second gear would be of benefit pulling hills. With only O, D, and 1 available, it will be shifting willy nilly.
    2000 Grand Marquis LS
    Mercury Owners Group member
    i don't think a shift kit will allow you to select 2nd. the purpose of a shift kit is to tighten up the shift points. the stock setup on an aod is to appease old geezers who don't want to feel the car shift. to creat smooth transitions when it shifts, the stock setup actually slips. slipping creates friction, friction creates heat, heat kills tranny . if you haven't already i'd put the money into a decent tranny cooler. that would help immensely. Scott (Lincolnmania) has one from an rv iirc on his town car
    Save a seal, club a liberal.
      You could do the 1 d 1 shuffle but its not recommended.
      1989 Grand Marquis LS
        Did that this weekend, decent size cooler. And Air Shocks, gets me about 3 inches lift.
          actually the 1 d 1 shuffle doesnt hurt it, it's designed to hold second gear in 1 if over ~15mph
          I have to do it all the time if the road i'm on is >15<30 mph
          GMNRadio DJ, Podcast Co-Host
          95 S10 93 Accord
            Originally posted by seneeb
            1 d 1 shuffle
            explain please
            :morons:
              start in 1, get up to about 20mph, move shifter to D. After it shifts, bring it back down to 1 and it will hold in second gear
              95 S10 93 Accord
                kind of what I figured.
                Will this work on the fly?
                  I think its Lentech that has a redesigned valvebody to give the 1-2-3/OD shift pattern you're looking for.
                  '80 Town Coupé
                    What's the problem with towing in 3rd again? Seems to me the decreased strain on the engine would more than "pay for" the increased strain on the direct clutch pack. There IS a balance here, and overdrive is IT. Don't use it.
                      I will use third for normal towing, but on a hill you will need to downshift and sometimes first is too low and third too high, need a balance.
                      Just curious how the trans temp gauge is hooked up? There is no sending unit. Is it inline, or is a hole drilled in the pan?
                        My wide ratio trans is a OD-2-1 pattern, so there is a way to do it, but it's not a kit, it's a matter of modding the valve body and trans case. And with a stock AOD, you also don't necessarily have to do a 1-D-1 shuffle. If you're going above about 30mph you can go from D to 1 and it will go directly into 2nd.
                          Won't drop into first?
                          have to test that, sounds like the answer that I can afford
                            you can put an aftermarket temp sender anywhere you want - I plan to put mine in the pan.
                              It will not go into first over about 15 mph.
