tranny pan
    tranny pan
    tomorrow i plan on pulling christine's tranny, just gotta move her to a flat spot in front of the house,lol. i'll get some twosome shots with her and shifty too if i can borrow my moms camera. ii'm kinda broke this week so the tranmission will not be going in after its pulled. reason being when i drop shiftys tranny i want to do the rear main seal, and i would rather wait to get the part before i put the tranmission in. now my question is, will upgrading the pan to a larger capacity help me any? and if it does, i'm assuming not to go with a chrome pan because,iirc chrome retains heat? and if thats correct is there an aod pan thats a deeper capacity and also has a spot for a tranny temp gauge? if not no big deal becausei can always pipe one in with the cooler lines, and i also know most aftermarket pans have drain plugs.
    my main concern is if increasing the capacity of the pan will help prolong the life of the tranny and whether i should get an aluminum or a chrome pan. would the pan haveing fins help with the cooling at all either? :dunno: :dunno:
    Save a seal, club a liberal.
    the stock pan is fine.......install a beefy transmission cooler.....that would be money well spent
    scott
      i'll prob. do that. main reason i was gonna get another pan was the drain plug. i could always do that down the line. now for the aftermarket cooler, where would i mount that?
        Use a frame rail cooler similar to this:
        I am thinking of getting one for mine after I get the trans looked at. Keeps making this squeeking/scraping/high pitched noise when I accelerate.
          thats a cool link, should i go with the 15,000 gvw or the 11,000 gvw
            probably the smaller one would work fine and not be overkill. This link might give you different options than just frame rail placement:
              Sweet!
