pcv screen
    pcv screen
    Well its a 91 gm and ive had an issue with the engine not running good with ac on. Also it was overheating on a 500 mile trip over the weekend. In the past 6 months i replaced the fan cluch, thermostat, coolant flush, egr, iac, distributer rebuild including tfi module, plugs and wires, cap and roter, maf, transmission, puter. Im sure im missing something here. Anymays i took off the plenum to chack the vac lines and change the pcv valve and there is no screen in the pcv hole. Will i be making a mistake by not putting a screen in there?
    My wife and I.sigpic
    Yes.
    Former panther owner
    1981 CV 351 4bbl
    1991 CV 302 EFI
      You'll have increased oil consumption if you don't use the screen. Motorcraft FA-1068.
        I ran mine without a screen for about 6 months. When I took the upper off for something, the oil was literally pouring out of it. I put a screen in and never had that happen again. Replace the rubber grommet while you're in there if its not soft. Once they turn hard, they do not seal properly anymore.
          After I posted this yesterday I went out and got the screen nobody had the grommet but the one in there is still somewhat pliable I can flex the top collar the sleeve part isnt very pliable though. How long do i have to change this screen?
            Man I was putting the screen grommet and pcv in and found a crack in the pcv hose what should I use as a replacement?
              I replaced mine with regular rubber hose.
                frack!
                man i love this car... the simple pcv job has now turned into thr removal of the air pump, new water pump, new timing chain and gears!!! hell i dont even have the plenum back on yet due to having to order the egr spacer gasket!!! i lleft it loose to weasle the spacer on but hell ill just take it back off and change valve cover gaskets, what the hell right? the wife said man thisgetting to be expensive but i said everything will be new except for crank, pistons, cam, and heads! i also went with gadgets suggestion on the ac belt they didnt have the # he said he uses i got 5060540 because they didnt have the 538 i hope it works because i live in bfe and its 90 min round trip to town. gadget will i be able to take up this little extra slack with the tensioner?
