I was thinking about putting in type F tranny fluid, since I'm doing a transmission fluid change anyway. I'm thinking the F will firm up the shifts and eliminate any slipping. Anyone tried this yet, and is it advisable? I know your only supposed to use mercon, but aod's being known for slippage, I thought a little type F would do a lot of good for much less effort than a shift kit.
type f instead of a shift kit?
1991 GM GS sedan "Love Boat" HO converted, Holley adjustable fpr, 3.27 Trac-lok - RIP
1991 Colony Park LS "Wally World Express" HO, 3.27 trac-lok - RIP
1988 grand marquis ls "grey ghoul" - RIP 1992 gm ls "superbeater"- sold 1993 F350 dually 7.3 IDI crew cab flatbed "killer" - RIP
1994.5 F350 Dually Crew Cab Flatbed, Powerstroke 7.3 "overkill" - Alive and kicking
1987 Lincoln Town Car "El Presidente" - Resting for winter, gonna be a beast!
2008 Mustang, no name - belongs to the wifeyTags: None
automatic transmissions are hydraulic devices. the fluid has 3 jobs... pressure, lubrication, and cooling. dextron III and type F are bout hydraulic fluids. dextron is thinner, F is thicker. a thicker fluid should build more pressure... which would cause a harder shift. but will it lube and protect all the parts correctly? i dunno. get a $25 shift kit!
grand_marquis_gt: "Wow dude, you got the GMGT sedan!"
there, now im cool too
dont use type f
if you want a different fluid, use the pensoil universal atf.....it's synthetic, and it made my aod shift alot better
scott
Originally posted by Jason91GMa thicker fluid should build more pressure... which would cause a harder shift. but will it lube and protect all the parts correctly?
For an example-----Putting 20W50 in a street engine with tight factory tolerances will cause more damage than good.
Originally posted by Evilcrownvici definitely would advise AGAINST putting that in there. our aods are designed for running dexron III and putting type f in there would prob screw it up.http://secondhandracing.com/Home.aspx
Originally posted by DuceAnAHalfwouldnt the AOD be desinged for Mercon since Dexron is a GM fluid spec?
Oil manufacturers have the same qt of oil meeting both specifications. I am not aware of anyone marketing a qt of oil which meets one and not the other.
Originally posted by MercracerOriginally posted by DuceAnAHalfwouldnt the AOD be desinged for Mercon since Dexron is a GM fluid spec?
Oil manufacturers have the same qt of oil meeting both specifications. I am not aware of anyone marketing a qt of oil which meets one and not the other.http://secondhandracing.com/Home.aspx
mercon=dextron
