car -87 MGM Colony Park
engine-'88 5.0 HO converted from EFI to Carb, msd all round, new wires, plugs, cap, rotor, etc. Spark Plug firing order/wiring is correct.
So my problem is I cannot seem to set the timing correctly. When I set the timing to 10o BTDC (where the book says it should be) the engine stalls at Idle and seems to be bogged down completely, however under hard throttle/high load it pulls strongly and smoothly. When I advance the timing further, the Idle increases to a maintainable speed but the engine pings and rattles under hard throttle/high load. I thought I would solve the problem by setting the timing to somewhere in between, but it is still stalling.
