engine parts list muhahaha
    muhahahahah engine rebuild parts list! all part #'s from summitracing.com I may not buy em from summit, but their site is easy to search I know this may not be a complete list, and is a work in progress
    Rotating assembly:
    Eagle Specialty Products 332 Stroker kit Part # ESP-16006030
    Rotating Assembly, 4.030 in.x 3.25 in., Forged Flat, Forged Crank, 5.40 in. I-Beam Rods, Ford, 332, Kit
    Cam:
    Erson Cams Hydraulic Flat tappet Part # ERS-E211011
    Camshaft, Hydraulic Flat Tappet, Advertised Duration 280/292, Lift .448/.478, Ford, Small Block, Each
    1250-4750 operating rpm
    Intake:
    Edelbrock Performer 289 p#EDL-2121
    Intake Manifold, Performer, Dual Plane, Aluminum, Natural, Square Bore Flange, Ford, 260/289/302, Each
    Carb:
    Holley Reman HLY-64-3609
    Carburetor, Remanufactured, Holley, 4-Barrel, Single Inlet, Ford/Mercury, Each
    Water Pump:
    Flow Kooler High vol # BRA-1654
    Water Pump, Mechanical, High-Volume, Aluminum, Natural, Ford, 302/5.0L, Each
    Lifters:
    Comp Cams Hydraulic lifters # CCA-832-16
    Yerbasic hydraulic lifters
    Fan:
    Flex-a-lite Flex Fan # FLX-1318
    Fan, Flex Type, Clockwise, 18.25 in. Diameter, Stainless Steel Blades/Steel Hub, Universal, Each (hrm, might even put one of these on the ranger lol)
    Gasket Set:
    Ford Racing gasket set. # FMS-M-6003-A50
    Valve Covers:
    Ford RAcing Polished. # FMS-M-6582-A302R
    Valve Covers, Stock Height, Cast Aluminum, Polished, Ribbed with Ford Racing Logo, Ford, Small Block, Pair
    Distributor:
    Mallory street strip # MAA-5770401
    Distributor, Magnetic Pickup, Iron Gear, Ford, Small Block, Each
    Oil Pump:
    Milodon High volume # MIL-18800
    Oil Pump, High-Volume, Standard Pressure, Ford, Small Block, Each
    Gear Drive (MUHAHAHAHAHAH ):
    Pete Jackson Gear Drives. # PJJ-289-9C-N
    Gear Drive, Noisy, Dual Idler, Ford Small Block, Kit
    Headers:
    Trick Flow shorty TFS-5178693
    Headers, Shorty, Steel, Painted, Ford/Mercury, Mustang/Cougar, 5.0L, Ki
    heads:
    World Products WRL-053030-2
    Cylinder Head, Windsor Jr., Assembled, 58cc Chamber, 180cc Intake Runner, Ford, 289/302/351W, Each
    Not sure what ignition to use, probably a mallory to go with the dist.
    There's a few other things i need, other than the obvious $$$$
    i figure this build will do nicely. Better than stock, not too much for desired applicaiton
    Dammit i need to win the lottery so i can order this shit!
    /sen
    GMNRadio DJ, Podcast Co-Host
    95 S10 93 Accord
    phew. i thought you ordered them
      not yet, saving money thankfully the old man (aka father) is going to assist in the purchase of most of these parts since the vic is going to replace the half scaled excursion (aka subaru forrester) as the freeway cruiser. we hope to have the engine and tranny in and tuned by spring.
      going to get the block machined first, .030 over make sure everything is straight and clean with no cracks etc.
      yay me excitered
      95 S10 93 Accord
        What bout the trans?
          Why a big flex fan? Should run an electric. Nice list though. Prolly need a different balancer-most strokers are 28oz inbalance. The newer 5.o's are 50oz.
            <--- gear drives
            :evil:
