Custom air cleaner
    Custom air cleaner
    can i put a aftermarket air cleaner on my car without using the hoses attached to it. something like this.
    well can i use these on my Grand Marquis. i was looking at a nice edelbrock one and it was sweet. i would pick it up only if it would work fine on my car.
      I think the top of the CFI unit it somewhat different than a carb top. Not sure if that will work or not. Believe it or not, you'll have better performance results from the stocker as long as the cold air tube is still present and hooked up. THose open element cleaners are a hot air intake.
        wheres this cold air tube located.
          all he is referring to is the air intake from the top of the core support leading to air cleaner...you know the stock air intake. That thing gets nice cool air outside of the engine bay.
            if i were to get this can eliminate all those hoses connected to the stock one and just run the new one.
              I actually had a edelbrock breather on my 84 Grand Marquis. I cant remember the size but it was kinda big. Had a thick tall air filter. But it worked fine on it. I couldnt tell a difference. I also had the crhome valve covers as well.
                what did you do to all the hosing and parts that connected to the old one.
                  Just plug that shit off.. and get a small breather for the tube comming from the pass side valve cover
                  1980 Lincoln Continental Mark VI Signature Series
                  351 4 bbl, AOD, 3.08 open
                  duel exhaust with cherry bombs
                    whats a breather and for which tube
                      cfi units are about a quarter inch bigger. Stuff for a carb wont directly fit. I had one on but i had to hack it up to make it fit.
                        ok well still whats a breather and for which tube.
                          I believe it's the hose coming out of the passenger side valve cover, right near the vacuum nipple you showed me yesterday
                          If you follow it up to the air cleaner and take the top off, there is the stock breather.
                          'nipple' hehheh...heh...hehhehheh...
                          Pete
                            ok. i still am going to try this out.
                              are you going for looks or performance? if performance keep the stock assembly and install a k&N filter. make sure your pcv valve is good before going to an open style air cleaner. I ran one for a little while and my crankcase pressured up and caused the gaskets on the intake manifold to leak, went back to stock the leak wasnt as bad but the damage was done to the gaskets so i had to replace them.
                              NA-15.78@91.21, 80hp shot-14.48@96.21
