Greetings everyone, I'm having some slight problems with my '87 GM. When at a stop light with the A/C on it starts to have a rough idle.. This problem can be cured by turning the A/C off or shifting into Neutral... From researching I'm guessing it's the MAP sensor. Could someone confirm this & give me more info on this issue(BTW I'm no car savvy mechanic)? Also I don't know if this is related to the same problem but when shifting from reverse to drive or vice-versa the car reallly dies down, and 1 incident cut off on me.. My guess is some sort of vaccuum hose... Thanks in advance for the help...
Need solutions to rough idle problems???
What he said.
Related, when was the last time it had a tuneup and a fuel filter?86 Lincoln Town Car (Galactica).
cleaning the IAC: on the car... open the throttle all the way and hose out the ports to the IAC in the side of the throttle body with throttle body/carb cleaner (engine off of course).
off the car: same thing... hose it out. just remember to replace the gasket as well.
I generally use the "on the car" method.
Originally posted by jayh View Postclean the throttle body too.
OK I sprayed the air intake/ throttle body cleaner around the throttle body and air intake but the problem is still persistent... Although the cleaner did help with calming the startup idle abit... Any more suggestions or solutions?@Ryan.Madison68
DO NOT USE CARB CLEANER IN A THROTTLE BODY!!!! That just makes stuff worse, there's a protective coating on the throttle body that's supposed to limit the amount of gunk that builds up there.
Anyway, have you checked for any codes? If there are any, they might be able to point you in the right direction.
How low is your idle speed? Wore out engines idle slower if they have never been adjusted.1989 Grand Marquis LS
There is no idle adjustment on an EFI car. Its set by the computer. That screw is a throttle stop, not an idle adjustment. CFI and carbs have idle screws, not multiport injection.86 Lincoln Town Car (Galactica).
