high revs on cold start
    My car (and any I've driven, really) rev much higher than normal idle on a cold start. The colder the start, the longer it will rev before it comes down to a normal cold idle - I've been told it's completely normal, I'm just wondering why the hell they do that? Gotta build up oil pressure or something? Gets the oil circulating? I have no idea, I'm just curious
    fuel doesn't vaporize well in the cold, so the engine is run at a higher speed to warm it up quicker so the engine will idle properly. There needs to be some heat in the cylinder for efficient combustion.
      Very cool. Thank you.
      When you shut your car off, does all of the oil drip down into the pan? Running off of the lifters and pushrods and all of the fun stuff? Does this leave them dry if you've left the car sitting a while?
      Sorry for the goofy questions but as you can likely tell by the thread I know not of these things.
        most of the oil drips back down, but a film will lay on stuff. If you leave it sit for months and years at a time, eventually the film runs off and everything is left dry. Thats when things start to rust internally.
          30seconds is the typical high(er) idle time. Incidently, the owners manual recommends running for at least 1 minute before driving after a cold start (winter time type cold that is).
          Alex.
            Only letting it idle for a minute seems wrong
              I don't have a minute to let it idle.
                it's for emissions and fuel economy..
                  there might be something wrong with mine, mine does it regardless of heat lol
                  1996 Mercury Grand Marquis GS
                  1965 Cadillac Hearse by M+M "Edgar"
                  1964 Mercury Comet Caliente
                    You don't need to idle it for a minute. The computer is programmed to allow a cold drive away condition. It says it right in the link that cld783 posted.
                      You don't need to, thats the beuty of fool injection. BUT, its a bit nicer to your engine if the oil start flowing before putting a load on it. (and since its lost on some of ya, winter, sub zero starts)
                      Alex.
                        yes, allowing some time to get the oil warmed up and circulating is a good thing for durability. The colder it is outside, the more important this becomes. Using thinner oils in the winter in cold climates helps with that. 20w50 doesn't pump very well when its well below freezing.
                          My car just seems to like it better when I let it idle for 2 minutes or so on a normal day, longer in winter - I wait til the temp gauge starts climbing.
                            You won't hurt anything by doing that, but you might waste a bit of fuel. I just start it, wait 15-20 secs (long enough to tune the stereo), and then drive away normally. I don't get on it until the engine's up to operating temp, but you won't hurt anything by driving normally.
                            The real way to make sure that you're getting oil circulating before you drive away is to make sure you're running the appropriate oil for your outside temps. Ford says that if the temp's going to go below -18C, but won't be above 38C, you should be running 5W-30. If the temp's going to be above -18C, and above 38C, then you should run 10W-30.
