Originally posted by 91grandmarquis
View Post
how long do you let an engine sit before changing oil?
just a little is fine. just make sure the seal isn't dry.
buy the filter wrench that's a huge pair of curved pliers. none of the other ones are worth a shit.Originally posted by gadget73There is nothing more permanent than a temporary fix.
"In science it is either physics or stamp collecting." - Ernest Rutherford
- Oct 2009
- 2878
- Keene NH
- Send PM
Originally posted by 91waggin View Postjust a little is fine. just make sure the seal isn't dry.
buy the filter wrench that's a huge pair of curved pliers. none of the other ones are worth a shit."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
I like the little circle wrench job thingy. There are a lot better it tight areas. Doesn't matter much with the vic but other cars would be hard to get the big'o'pliers in there.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
I have the band style as well, use it on the boat for fuel filter swaps. I don't use a filter wrench on my own car. If you need to use it regularly, chances are you're putting the filter on too tight anyway. You're supposed to install the filter hand tight, not with the wrench.86 Lincoln Town Car (Galactica).
I have both filter wrench types. Got the pliers when I had a car that had virtually no clearance between the filter and anything else to get the band type over it. the pliers type is good for crushing cheap filters too.
I've always put a once around coat of the old oil on the filter gasket and tightened it by hand... but sometimes I still need the pliers to get it off. I don't think I'm THAT strong when tightening it... but sometimes I still need the wrench. I was kinda scared when I took the filter off the escort for the initial oil change after I got it. It was like taking the top off a milk jug. freakishly easy... almost NO resistance. the new filter went on much snugger than that.
I like the pliers type because I do lots of oil changes where I usually wasn't the last one to change the oil on it. I don't ever put it on with the pliers, but I usually need them to take the last one off.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by gadget73 View PostI have the band style as well, use it on the boat for fuel filter swaps. I don't use a filter wrench on my own car. If you need to use it regularly, chances are you're putting the filter on too tight anyway. You're supposed to install the filter hand tight, not with the wrench.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
I've had to do the screwdriver and hammer routine a few times when some hack has cranked a filter on so tight that it just crushes under the filter wrench. Once was on my stepdad's Harley. He had to walk away from me as I was using a hammer and a screwdriver to punch holes through the filter in order to turn it.86 Lincoln Town Car (Galactica).
