how long do you let an engine sit before changing oil?
    Originally posted by 91grandmarquis View Post
    Filter wrench would help you. Did you smear some oil on the new filter O-Ring. It helps it seal better.
    yup...not really sure how much to use
      just a little is fine. just make sure the seal isn't dry.
      buy the filter wrench that's a huge pair of curved pliers. none of the other ones are worth a shit.
        +1 on the wrench, the others are hard to slip on and off in weird angles and such.
        1985 GMC 1500
          I like the little circle wrench job thingy. There are a lot better it tight areas. Doesn't matter much with the vic but other cars would be hard to get the big'o'pliers in there.
            I have the band style as well, use it on the boat for fuel filter swaps. I don't use a filter wrench on my own car. If you need to use it regularly, chances are you're putting the filter on too tight anyway. You're supposed to install the filter hand tight, not with the wrench.
              Eleven years, eight months, two days, give or take an hour.
                I have both filter wrench types. Got the pliers when I had a car that had virtually no clearance between the filter and anything else to get the band type over it. the pliers type is good for crushing cheap filters too.
                I've always put a once around coat of the old oil on the filter gasket and tightened it by hand... but sometimes I still need the pliers to get it off. I don't think I'm THAT strong when tightening it... but sometimes I still need the wrench. I was kinda scared when I took the filter off the escort for the initial oil change after I got it. It was like taking the top off a milk jug. freakishly easy... almost NO resistance. the new filter went on much snugger than that.
                  half hour after reaching operating temp, or three 12oz beers. which ever comes first
                  [URL="http://www.cardomain.com/ride/3358314"]
                    I like the pliers type because I do lots of oil changes where I usually wasn't the last one to change the oil on it. I don't ever put it on with the pliers, but I usually need them to take the last one off.
                      Yep, hand tight, hand off, no screwdriver poking necessary
                      Pete
                        I've had to do the screwdriver and hammer routine a few times when some hack has cranked a filter on so tight that it just crushes under the filter wrench. Once was on my stepdad's Harley. He had to walk away from me as I was using a hammer and a screwdriver to punch holes through the filter in order to turn it.
