AOD
    AOD
    Dear Gurus,
    I seem to bebuild the automatic transmission on my 89 Colony Park every 30k. I live in the mountains (nearest supermarket is 38 miles/75 minutes away. I've been driving in overdrive unless I was pulling a mountain - gear of choise. Should drive be my gear of choice except Interstate? PS: Virginia to Canada 23 mpg.
    Donald McCaig
    1989 CP Scottified steering, suspension and big brakes, 16 in wheels, A-pillar oil & temp gauges, remote entry, backup sensor, tailgate wiper, custom console & trash, tranny & ps coolers, 3 cell radiator, electric fan, dual exhausts, battery isolator, hellas headlights,deer pusher,wads of dog hair.
    Yeah, sounds like you are burning up that OD band....
    Ever considered a mild performance build AOD? A shift kit firms those shifts up, But also makes everything last longer because the shifts happen right away, and none of that slow engaging crap...
    Just something to consider...
      i would use D unless im on the highway in your case.
        Keep it in D and get a tranny cooler if you don't already have one.
          you definitely need a tranny cooler
          a performance built aod would probably last alot longer too.......it might be worth the drive to pa so i can get that aod hooked up.........could prob do a performance aod for you for around $1200 installed, cooler and all
          scott
            Hill climbing needs D. THe overdrive band in an AOD is weak, so if you do a lot of hauling, mountain climbing, or whatever that puts added strain on the transmission, a cooler and an upgraded OD band and OD servo are a great idea. A properly built AOD is pretty tough, but in stock form they aren't so hot.
              Dear Gurus,
              I'd take Scott up on his kind offer (plus I'd like to buy him a beer) but I've just spent 1100 to have the tranny rebuilt. Can I put a tranny cooler and/or shift kit for cheaper?
              Donald McCaig
                Originally posted by yucatecd
                Dear Gurus,
                Donald McCaig
                a shift kit costs under $100 and a good tranny cooler goes for $50
                  what he said.
                    realistically how much engine output can an aod handle?
                    with performance shift kit, rebuild, and a decent manual valve body
                    GMNRadio DJ, Podcast Co-Host
                    1984 Ford LTD Crown Victoria - Drag Car.
                    99 Ranger 2.5 - Parts hauler and Pit truck.
                    03 Mustang 3.8 Convertable - Head Gaskets fukered up
                    95 S10 93 Accord
