I don't need them, I'm just curious what will actually fit in there under our intakes with little to no modification.
what's the story on replacement valve covers
- 2008 Mercury Grand Marquis Ultimate Edition - Daily driver - 4.6 2 valve Mod motor, 4R75E, 2.73s. Bone stockTags: None
As far as I know, anything that will fit a Fox 5.0 HO will fit. Unless of course I am missing out on something such as a extra hole we have in our valve covers or something.'97 Cadillac Catera - 3.0 DOHC V6, 75k
Soon... Any '95+ Panther!
CLICK ME! Parts For Sale, SUPER CHEAP!!!
are you asking about aftermarket valve covers?
need 1/2" intake spacer to run the tall aftermarket valve covers.......some of the tall aluminum valve covers require a 1" intake spacer.
aftermarket and OEM I guess - I saw a set of billeted covers for a mustang and thought they'd look nice. They could have been Ford racing I think, but all that was on 'em was the blue ovalsigpic
302 valve covers are 302 valve covers really. They all bolt up. Some are taller than others, but thats about the worst of it. You can run carb or EFI style covers without problems. Mustang guys need EFI covers or its a pain in the ass for them to add oil.86 Lincoln Town Car (Galactica).
you can use the 86-93 high output cast alum valve covers on a box, but you have to break the wings off the 710 cap
just for the record, if anyone is to buy EFI 302 valve covers, make sure the oil fill is in the right location. Some of them are different. Ask me how I know.Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
New Project: Vicky II - 1981 Ford LTD: 61,XXX miles, virtually rust free. Currently For Sale
Dont have to break off the wings. If you pull up on the outside it will pop off of the inner part then you have room to unscrew the inner part. then when your done screw the innner peice back on an snap the top cover back on.
'90 LX 5.0 mustang
Big plans
i'm getting a set of the ford racing EFI series valve covers this summer (stock hieght) and a spacer type gasket to give my roller rockers some room. If I need to I will pop in a 1/4" upper intake spacer. Just what i'm doin, but check out those valve covers, they look pretty good.Finally have an on the books porting/custom fab business!
Originally posted by merc91 View Posti'm getting a set of the ford racing EFI series valve covers this summer (stock hieght) and a spacer type gasket to give my roller rockers some room. If I need to I will pop in a 1/4" upper intake spacer. Just what i'm doin, but check out those valve covers, they look pretty good.Originally posted by hemihotrod402 View Postjust for the record, if anyone is to buy EFI 302 valve covers, make sure the oil fill is in the right location. Some of them are different. Ask me how I know.Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
thanks allot for the info, i'll definelty keep an eye for that when picking some covers.Finally have an on the books porting/custom fab business!
when you run an intake spacer do you need another gasket? lower intake - gasket - spacer - gasket - upper?sigpic
yes
