i'm scared
    i'm scared
    I found out about the TV bushings going on the old 5.0's so I decided to check mine. I HAD NO TV BUSHING!! Great...So I replaced the bushing -- the transmission shifted fine before, and it still shifts fine but is there anything I should do or be worried about?
    You saved your butt.
    You should be fine. How many miles are on your car/trans?
      check the fluid level and condition. if its still red, doesnt smell cooked, and doesnt have shiny stuff in there, its fine.
        61,909 miles, transmission fluid changed at 59,000
