cleaning iac again
    the screw head will be larger than the tube, so it can't get sucked in. There isn't all that much vacuum on the egr port, and there are enough spots that things can't pass through that you'll be fine.
      good to know. thanks again.
        I see what you meant about the vac line. It is tiny. The green line is less than 10" long, it plugs into something attached to the front of the plenum, almost right next to the egr valve. My car was made in feb of 90 if that helps you narrow down when they moved it.
        thanks again - i plugged the line with a screw and drove around for a bit. my engine sounds and feels healthier at idle...steadier? does that make sense? i am not knowing enough to describe it exactly but there is a difference. when i womp on it from a stop, it goes almost right away. until today when i would mash my foot in the gas there would be a very noticeable spot where the car just did nothing. now that spot is a fraction of a second compared to a second or more.
          yeah thats the EGR regulator. Thinking about it, it seems to me all the 90-91 cars have the regulator there. 89- have it over on the fender.
          Since it made a difference, shoot some wd40 in the vacuum line. It might un-stick the regulator. There is also a little cap on the regulator that has a filter underneath. Clean that filter if its still intact, or remove the remains if its not. Shoot some wd40 down the little tube that sticks into the middle of the filter. No guarantees that will fix anything, but its cheap and it just might work. If it doesn't help, you probably need a new egr regulator.
            Into the line going to the regulator? While under vacuum? Will give it a whirl.
              yeah, under vacuum, otherwise it won't suck the lube in.
                i used to get a bit of a clunk from the rear of the car then it would lose a good bit of momentum immediately
                um that's probably overdrive kicking in......lemme guess around 38 mph?
                  I might not know much but know what the 'shifting into OD' clunk feels like With this, there would be a noticeable clunk when I would take my foot out in any gear or at any speed.
                    Possible u-joint play? I get a bit of a clunk as well and that's what I attribute it to.
                    1986 Grand Marquis LS 2 Door
                      Whatever it was, it's gone now had planned on doing the u joints this month or next
