right turn signal is sticking
    my lincoln's right turnsignal stuck for a while, the green arrow came on but it didn't click and the lights outside didn't work. After letting the car sit for a while it worked again. And it works now but any ideas on what might be about to break? if anything. Thank!
    what do you mean it stuck?
    Start checking your bulbs - My blinkers becme sporadic on one side and it was just a bad bulb. Try and catch it next time and note wich bulb is out, or check them all for breaks our cauliflowered filaments.
    Try your hazards - that will help to diagnose.
      Replace the flasher module. Like 5bucks, it's the round thing that is in the fuse panel under the steering wheel. Mine did the same thing a few years ago.
