alright i've got a nice low km's lopo motor that I would like to keep in thier if possible, but I want to swap on GT40P heads and hopefully a xe258 cam.
I will be converting to mass air, all the supporting mods... basically everything up from the long block, and getting a professional tune to bring it all together.
It is my daily driver which is why I don't want to be getting into getting another motor to build up and have to make fit and the pop-up problems that always show up... and money is somewhat of an object, I can and will buy everything the swap will need, and of good quality...I just can't afford to be buying different cam's and heads and rockers and all that, through trial and error with clearences, not to mention i'm hoping to make this a 1-2week job tops so if i can get a surefire list of parts together for the swap to go as smooth as possible i would be a happy guy.
All that being said, so ya's know my plan, lets get into the tech and after lots of reading these are my questions at the moment and any other points you guys can add on the subject would be appreciated allot...
-with stock lopo pistons and GT40P heads, will the comp xe258 cam work without piston/valve contact? ...it's high lift but short duration so i'm not sure...and i will be using 1.6 rockers of course.
-will I still be able to pass sniffer emissions testing (assuming engine is in ideal running order) with the different EGR setup on the GT40P heads, and using the xe258 cam?
-.510" springs won't do the job with that cam will they?
Thanks guys, If I can snag this summer job I'm going to be needing lots of help with motor/tranny info as I can not think of a better way to finally make and spend some cash, than on the old girls motor.
