I full throttle and it take like two seconds till the car notices it? I have a fresh tune up new map sensor, new fuel pump, injectors cleaned out, lots of new vacuum lines. So what can this be?
Hesitation on full acceleration on sefi?
how old is the fuel filter? Ever checked it for codes? A TPS with a dead spot can cause this too, may or may not show up on a code scan.86 Lincoln Town Car (Galactica).
tps is new and tuned fuel filter two years old maybe. I know still have to redo the film sensor could that be it.sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Change the fuel filter first, its about an annual thing.
whats a film sensor?86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostChange the fuel filter first, its about an annual thing.
NA-15.78@91.21, 80hp shot-14.48@96.21
the only parts in the distributor are the pickup, or bolted to it there is a TFI module. There is no film sensor.
If you look at the factory service intervals, I'm pretty sure it has fuel filter replacement at 12,000 miles or 12 months.86 Lincoln Town Car (Galactica).
how would i go about measuring fuel psi put a gauge on it right lol. I havent checked timing yet either. Idk I gave it to ford they said tfi module was bad and just pulled the spout to solve the problem of it stalling. I putting new tfi module on this week. Maybe that will fix it.sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
theres a test port for a fuel pressure gauge on the front passenger side corner of the fuel rail. It looks like a valve stem you'd find on a tire. There may be a black plastic cap on it.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postthe only parts in the distributor are the pickup, or bolted to it there is a TFI module. There is no film sensor.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Yes, I know what TFI stands for. I didn't know if he meant the pickup which is a sensor, or the TFI module, which is not a sensor. Neither item is quite what I'd call key shaped, so its still not clear.86 Lincoln Town Car (Galactica).
