This has happened twice to me. I'll be at a low speed, and I'll push the gas to go, and literally nothing happens, then all of the sudden about 2 seconds later the car wakes up and goes. Is this an engine or trans issue? And what specifically is it?
Hesitation
the linc?sigpic
Sounds like a dead accelerator pump in the carb. Look down the throat of the carb with the engine off, and open the throttle. If you don't see two streams of fuel squirting as you open the throttle, thats your problem. Time for a carb rebuild if thats whats going on.86 Lincoln Town Car (Galactica).
Originally posted by 1990LTD View Postthe linc?
Originally posted by gadget73 View PostSounds like a dead accelerator pump in the carb. Look down the throat of the carb with the engine off, and open the throttle. If you don't see two streams of fuel squirting as you open the throttle, thats your problem. Time for a carb rebuild if thats whats going on.
That was 3 years ago. Has it been sitting? Those rubber diaphragms dry out and fail. The squirters also clog with dirt.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostThat was 3 years ago. Has it been sitting? Those rubber diaphragms dry out and fail. The squirters also clog with dirt.
Originally posted by 83countrysquire View Postwhat if that happens in sefi?
Or, start a new thread specific to your issue. Different can of worms entirely.86 Lincoln Town Car (Galactica).
If its carburated try this
Originally posted by insomniac391 View PostThis has happened twice to me. I'll be at a low speed, and I'll push the gas to go, and literally nothing happens, then all of the sudden about 2 seconds later the car wakes up and goes. Is this an engine or trans issue? And what specifically is it?My wife and I.sigpic
