If it won't move, chances are fair that it hasn't been moved. If you can see the screw tip touching the tab on the throttle lever, its likely set properly. If its not, try bending the tab a little bit. It should bend if you apply a little persuasion in the form of pliers.
throttle sticking?
Originally posted by gadget73 View PostIf it won't move, chances are fair that it hasn't been moved. If you can see the screw tip touching the tab on the throttle lever, its likely set properly. If its not, try bending the tab a little bit. It should bend if you apply a little persuasion in the form of pliers.sigpic
