Hi,
I have this book from 'Car Tech' named "High Performance FORD Engine Parts Interchange" by George Reid.
My Tudor has I believe the 'F' class engine, though it was manufactured in Canada. I believe the long block assembly is a hodge-podge of 302C , with a 351 (possibly Windsor), and the fox-bodied dual sump oil pan.
I have several questions in one post, so answer if you can:
According to this book and others, the stock HP is 200@4200rpm for this EFI.
The torque being 270@2000rpm. I have the K&N box air filter, a mustang H-pipe, with twin 18" cherrybomb glasspacks. Cap and rotor have brass fittings. About how much improvement on these numbers do I have?
According to the book, if it has 302cid cylinder heads (E5TE-PA/E7TE-PA), the displacement at TDC is 62-65cc. It has the same displacement for the 351W heads (E7TE-PA). Notice the ID# and displacement is the same, and looks like either head could have been bolted on.
(If I look at the left side of the engine, near air filter, it looks like there is an extra un-bored exhaust port, and the manifold staggered back)
Now, I figure that due to which ever head is actually bolted on, during 1985-93, the non-HO displacement in the head, and the concave piston head lowered compression even though it is listed at 9:1. If the piston head was replaced with a notched type or a shallow head, the piston and head would clash. If this is the case, is there anyway to get more power from the stock setup without replacing the heads and pistons?
Exhaust manifold: I've read that the stock headers, are actually better for power than using en-equal shorties. Is this true?
If I'm mistaken here with any of my assumptions, let me know.
Thanks.
Thanks.
