weird idle on start and hesitation
    well that is fine
      when was the last time the car had a full tune-up? fouled plugs can do it. id see if you can get the belt to not squeak too and yea 20 year old plastic vacume lines dont like being touched
        well that is fine
        yeah it's 650 I believe, but it's hard to tell with the little lines on the small tachometer, probably easier on yours. if i give it the SLIGHTEST bit of gas the vibration goes away...maybe bring it up between 650 and 700 revs and it's perfectly smooth
        it doesn't shake itself apart or anything that bad, but it's noticeable.
          mine shakes a bit... i figured it was just the old cratered motor mounts.
            about mid-winter, motorcraft plugs/cap/rotor, 9mm ford racing wires. it doesn't seem like it's missing anywhere
              i might have to join the thought of a tps then
                Target idle is I believe 672 rpm, so 650-700 is right on the money.
                  I replaced it with a different one but the problem remained. The weather is shit today so I can't go out and pull the IAC off to clean it. fuck.
                    If you raise the rpm and hold it steady, do you still feel the vibration?
                      86vickylx that is a negative. goes away when i hold it steady
