Mine used to idle really rough, like a large camshaft after I swapped to the h.o., went through and cleaned all my grounds very good and made sure they where all tight. The rough idle cleared right up.
weird idle on start and hesitation
Originally posted by jayh View Postonly make one change at a time!sigpic
test the tps, might have a dead spot
Analog voltmeters are your friend for that. Digital is nice, but sometimes it just doesn't tell you what you need to know. Testing a TPS for dead spots is one of those times.86 Lincoln Town Car (Galactica).
Spraying the bejesus out of the TB and cleaning it didn't seem to fix it completely, neither did the other TPS. I didn't pull off the IAC and clean it because I was unsure of how and didn't want to screw it up putting it back on.
I've noticed my idle seems to vibrate the car a little bit more than it does with the throttle barely depressed. Any idea about that? Tomorrow I can pull off the IAC valve and clean it completely if I find out how tonight.sigpic
Pull the codes, ground the wire in the self test input connector. http://fordfuelinjection.com/?p=13 Since you have a check engine light, that should be easy enough. You can also find the codes and their meanings on this site too.
I can test for codes without a reader or anything?
Am I reading this right? Ground those two pins, turn the key to prime the fuel pump, and just count the blinks? I'm a little unclear on the pauses etc between flashes but I can read the page over as much as I want. Thanks, this will likely really help me...I had no idea I could test for codes myself. Last time I went to the garage to get them to hook it up to the computer to pull codes, it took like 30 minutes because he had to find adapters and connections etc that could put something together to read a computer as old as mine......wtf?sigpic
Originally posted by 1990LTD View PostI can test for codes without a reader or anything?
Where's the STI? I notice it is apart from the main test harnesssigpic
I know the trapezoid job is over on that fender so the single harness must not be far off. thanks guys, i will let you guys know how this goes tomorrow.sigpic
Originally posted by gadget73There is nothing more permanent than a temporary fix.
out of curiosity what is your idle rpms?~David~
Looks like about 650-700sigpic
