I got my carb in the mail today, Holley 600 4bbl model 80457. Now I need a sweet manifold, hot cam, distributor, MSD 6al and a fuel pressure regulator. Then I will get a set of e7s and port em and I will be set. All I can say is that this made my day alot better.
One step closer.
One step closer.
My rod is glowing, my bead is clean, my middle name is acetyleneTags: None
I have run Weiand, Holley, and Edelbrock manifolds. My prefernce is Holley unless you are using edelbrock components. Weiand is owned by holley and if you can find weiand stuff made before the buyout, Weiand is teh shiznit! After the buyout, holly downgraded teh weiand stuff so it wouldn't eclipse holley branded intakes.
Holley #1
Weiand #2
Edelbrock #3 (unless cam and heads are edelbrock. Those power packs really do well!)2008 Mercury Grand Marquis GS Bone Stock
The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
