my towncar keeps overheatin
    the thing will get hott and then it will boil over into the overflow tank for a while so i have to wait for it to cool. Upper radiator hose is boiling hot. Any ideas?
    Thermostat is sticking most likely...
    Replace it, flush the system...
    And make sure to bleed all the air out of the system...
      yep if the car hasnt had any cooling serivce recently that you know of, replace the Tstat and give it a good flush. Check out your fan clutch too... you should not be able to spin it very easily (engine off) when its hot.
        Take a look at your radiator too as mine would still overheat after I changed the t-stat. So I swapped one of my parts car which was recently replaced and problem solved.
