Carb rebuild tonight... sorta...
    I finally got my jets for my carb, thanks to Parker Carburetion (www.parkercarburetion.com) and picked up a carb rebuild kit.
    Im not going to rebuild my carb totally, but I am going to do the following:
    - Install new power valve
    - New jets (going to try the #48's)
    - Set the float levels IAW factory levels
    Lets hope this helps!
    Also, I am going to tweak other things as well... Mostly in the name of efficiency and power... Trying to get a happy medium..
    Once I get the carb going good, im going to install my Chrome V/Cs and clean up the motor!
    GOin a Jetten Jetten Jetten! Now all you need is a NAWS plate!!!!
    2008 Mercury Grand Marquis GS Bone Stock
    The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
      Watch those replacement power valves. When I rebuilt that shitty carb, the power valve didn't fit right. Fucking junk.
        What's taking so long? This should have been in about 15 minutes
          15 minutes x 6?
          '80 Town Coupé
            I'm tellin ya mang, sixpack CFI. We can make that happen.
              Goddamn replacement power valve. :nonono:
              I put the one from the kit in, and it made my car run like ass.
              I put the old one back in, tweaked my settings, and all of a sudden, im running good again. WTF???
                Same ratings?
                  that sixpack cfi sounds like a plan thain
                    No, the one in the rebuild kit was a pile of worthless shit.
                    No six pack CFI!
                      why not, other than the fact i don't believe theres a 6pack intake manny that would support a motorcraft 2150. if it fits a 2150, it'll fit a cfi
                      hooking the tv rod up wpuld be the bitch :drug:
                      Save a seal, club a liberal.
                        No, what I meant was that did both power valves have the same vacuum rating?
                          Yes. I think the stockies are like 6.5...
