351W ?
    351W ?
    we're rebuilding a 351W HD out of a 95 F250, and was woundering if there's anything different in this engine compaired to other 351's?
    we did find out it takes metric rings, and the oil pan gasket for a 96 explorer 302 is off by 1 hole.
    anything else?
    ---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
    ---1985 Grand Marquis 2-door., Fresh 5.0, slick-top, GT40P's, 1.7 RR's, FRPP headers, 3G alt., Weiand Stealth intake, 650 cfm holley, 2.5" side-exit exhaust, Mark 8 elec. fan, 3:55 Posi, Bucket seats, custom center console. My Toy
    The block should be an F4TE casting, which will accept roller lifters, so that's a good thing if you want to use a roller cam.
      yes it is a F4TE block, and it does have the roller cam and lifters, just curious if the gaskets are the same as any 351, i do know that these mitric rings don't come to cheap.
        yea the 351 block is wider than the 302 block, so it takes a different oil pan and gasket
        puttin one in a 88 vic here.....it's all rebuilt and ready to assemble, i'll let you know if i find anything weird
          I recently heard you can use standard rings as a substitue, but I dont know how true that is.
          in stock trim, that motor cant breathe
            nope, standard rings don't fit in the grooves, standards are to big, that's what we bought first and had to take back.
              Very nice! Are you keeping it EFI or going to carb?
                going to be carbed, it's for my cousins 85 bronco
                  I think all the Ford smallblocks went to metric rings sometime in the early 1990s, maybe 94? If you change the pistons you can put standards in there.
                    I'm looking at the parts catalog right now....if the regular set doesn't work, you have the metric ring set.
                    E458-K, moly set, $104.99 retail, or $71.90 my cost plus shipping.
                      we bought the complete re-ring kit from summit for $195.00, it even came with main bearing, and around here they were wanting $114 just for the rings.
