How does it sound in the interior? Is there a drone? I really want to do this (all my saving is beginning to pay off lol) and from all these youtube videos. I've heard a lot from the outside, but not much from the inside. I'm all for a loud exhaust, but we had a loud muffler on my dad's truck and it was driving me insane whenever I had to drive it because of the interior noise.
To all who are running no cats and Magnaflows
Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
New Project: Vicky II - 1981 Ford LTD: 61,XXX miles, virtually rust free. Currently For SaleTags: None
- Oct 2009
- 2878
- Keene NH
- Send PM
I can hear my dual magnaflows over moderate music under acceleration inside with 4 cats. If that is any help. My truck has no cats and dual magnaflows off a 350 with manifolds and it is very loud inside, however we are talking a completely different vehicle."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Not so loud.sigpic
I had the car out for a romp on the highway today, I almost forgot how fun it is. Cruising at like 1900 revs, I had to have the music up a bit louder than normal, but you gotta remember I was doing about 100 with winter tires so road/tire noise and vibration is a factor. I haven't had real tires on since the mufflers but I'll report back when I do.sigpic
Mine resonates pretty bad but I also have it dump before the axle.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
lol, i have straight pipes and cats and its not even that loud inside
stock duals and magnaflow cats and mufflers... gets noisy behind the car (not real loud though, but loud enough to get your attention)... but you can barely hear it in the car or even in front of the car. without some tail pipe flares (tips to a larger size) it stays pretty directional.
i've got headers to 2 hi-flow cats, and then dumped flowmaster super 44's at the axle and its not to bad inside. Pretty loud and throaty outside (but not ignorant loud) but not much noise inside only at higher load low RPM's.Finally have an on the books porting/custom fab business!
I have no cats with Magnapacks on the Linc, with a cammed 408w pushing air through them. Kind of useless for comparison :p
'80 Town Coupé
Straight thru Maganaflows are usually pretty good in the car. The XL Turbo line I can't talk about as I have only heard about them, never used them. I can see them drone a bit due to the hollow chambers though.1990 LTD Crown Vic w/ dead 5.0
1984 Pontiac 6000 cammed 2.5L Iron Duke
1986 F-150 300 6cyl 5spd.
1994 Crown Vic... Free, bad trans?
