Furthermore proof that our tech is MUCH better...
Gotta love how people simply start mocking. There was one decent answer tho. Once you have all the parts, probably it becomes a matter of changing out the engine bay wiring harness, then most everything else will just plug in. fuel lines from frame to engine need to be changed, but they should disconnect so thats not much of a problem. Do CFI cars have a fuel return line? if not that could be a problem. also not sure about the pump capacity, but thats probably OK.86 Lincoln Town Car (Galactica).
CFI cars do have a return line..
I'm not sure as to how powerful the intank CFI pump is compared to the EFI intank pump...
But it would actually be a good swap for someone to do... Convert to HP while you are doing all that tho..
Get a flat tappet cam with very similar specs to a stock HO cam, and that car would really boogie!1983 Grand Marquis 2Dr Sedan "Mercules"
Ah, I barely remember BON, haven't been on there for like 5-6 years.
Once they got shut down a couple times, and then C V N came around, I went over there. I was the 4th person on C V N. It was a decent place....years ago. Oh well...Builder/Owner of Badass Panther Wagons
Check this out.. LOL Fuck them............http://www.crownvic.net/ubbthreads/s...=&fpart=1&vc=1The Best
the flow rate is what i'd be concerned about, not the pressure. insufficient flow under load will make the pressure drop and the engine will fuel starve.86 Lincoln Town Car (Galactica).
