Furthermore proof that our tech is MUCH better...
    Has anyone completed thie mission if so was it succesful? I would like as much info as possible if anyone can help me out.. Thanks
    Read. I'm sorry Nate, but those guys are fucking idiots :nonono:
    Gotta love how people simply start mocking. There was one decent answer tho. Once you have all the parts, probably it becomes a matter of changing out the engine bay wiring harness, then most everything else will just plug in. fuel lines from frame to engine need to be changed, but they should disconnect so thats not much of a problem. Do CFI cars have a fuel return line? if not that could be a problem. also not sure about the pump capacity, but thats probably OK.
      CFI cars do have a return line..
      I'm not sure as to how powerful the intank CFI pump is compared to the EFI intank pump...
      But it would actually be a good swap for someone to do... Convert to HP while you are doing all that tho..
      Get a flat tappet cam with very similar specs to a stock HO cam, and that car would really boogie!
        Well, Nate, if you read this I have about 95% of the stuff you need. Intake, wiring, etc....schematics...
        I will not post "over there" anymore.
          Thanx for speaking up, justin
            Hmmm, I think BON used to do this kind of thing...
              Which kind of "thing"?
                Claiming to hate a website yet visiting it just as much and talking about it constantly.
                The only thing that hasn't been done is screenshotting.
                  Actually
                  Linky...
                  -Michael
                    Ah, I barely remember BON, haven't been on there for like 5-6 years.
                    Once they got shut down a couple times, and then C V N came around, I went over there. I was the 4th person on C V N. It was a decent place....years ago. Oh well...
                      Check this out.. LOL Fuck them............http://www.crownvic.net/ubbthreads/s...=&fpart=1&vc=1
                      The Best
                        39 PSI from the CFI pump, for future reference
                          the flow rate is what i'd be concerned about, not the pressure. insufficient flow under load will make the pressure drop and the engine will fuel starve.
                            That is what I'd be concerned with as with a CFI car you are only feeding 2 injectors and with an efi car you are feeding 8.
                              And to this day, I still have no idea the flow rate of CFI injectors...
