Can you hurt an engine
    can u hurt an engine by riding around with damaged header gaskets, because i want to bring out my Caprice so bad I'm about to cry.
    I wouldn't think so, other than risking burning plug wires, wiring harnesses, or anything else around where the manifold/header is leaking.
      awesome cause that bitch comes out today!
        it would take alot of miles but you can eventually burn the exhaust valve/valve seat up
        gaskets are cheap?
          gaskets are cheap?
          I'm gettin some from Summit for my birthday which is the 25th. Still, they're only 30$.
            you can also use red rtv- $5
            alot of people do not know this
              Really? I might try that if I do headers on my truck.
              I know Ford has this goop that they recommend for manifolds and stuff on the diesel trucks.
                I usually use hi-temp Never-Sieze on the side of the gasket that goes to the cylinder head flange; and that Copper Seal crap on the side that goes to the header flange.
                  I dont even use a gasket, just red rtv
                  learned this trick yeas ago from a racer, I was very very skeptic of doing it on street stuff, then years later I found out ALOT of turbo guys do this, then I did it myself, more or less being cheap at the time, then I found out alot of people do it
                  I found the bolts dont loosen up over time like headers with gaskets and I have never had a problem. I dont doubt some people are skeptic, I know I was for a LONG time
                  speaking of which, OP if you have headers, have you made sure all the bolts are tight?
                    what exactly are they?
                      the bolts that bolt the header to the head. get a 7/16 wrench and make sure they are all tight, if you havent burnt the gaskets up yet, they may just need to be tightened up
                      this is why they make stage 8 locking fasteners, but those things are just a pita imho
                        I've made both man and machine cry.
                          My Malibu used to make me cry with the Doug Thorley headers. I couldn't get those things to stay tight. The BBKs on the CV have been good to me. I feel like crying right now.
                            they dont need to be tightened, they blew apart like confetti one time when i floored it before it was up to operating temperature.
                              the copper rtv is more designed for this sort of stuff.
                              and I'll say again, as I have many times in the past. The reason for constantly loosening header bolts and blown header gaskets is usually a warped header flange. No matter how much magic stuff you use, if the gasket surface is not flat, its never going to maintain a seal. If things are flat, you can use $5 exhaust manifold gaskets and it won't blow them.
