so today i washed my engine at the car wash.everything was cool.i leave the wash and look at the dash and see my red engine light on. I pull over, cut the car off and check everything.looks good, so i cut the car back on and head back home.On the way, it cuts back on again, but cuts in and cuts out.so when i get home i disconnect the oil sender to see if thats it.Nope, light still on.so then i disconnect the temp sender, and the light cuts off.so i plug the oil sender back up and keep the sender disconnected and the light stays off. does this mean i need to replace the temp sender?
coolant temp sender dead?
Only if the light is not on because the car is overheating.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Only way to confirm this would be to install a temp gauge and actually monitor if you are overheating.~David~
Well I relplaced it and it hasn't come on since. The old one was orginal it looked like and kind of corroded,so I guess it's fixed.sigpic-The Crown(Kodiak)1989,150K Miles,5.0LOpo,autolamps,slicktop,power windows and locks,yet still not good enough to be LX:confused:
Get a good temp gauge! Death to idiot lights!sigpic
