Official Exhaust Video Thread (POST YOUR VIDS!!!)
This is a sticky topic.
    Same as before, BBK 351W swap shorties, no h or x pipe, and 2-chamber flows.
    Good to hear after being parked for so many years. Could never get rice to race if I ever did that at lights.
      1988 Mercury Grand Marquis: HO EFI302, Thumper E7 heads, BBK shorty headers, Cat-less 2.5" H-pipe, down-sized to 2.25" pipe, down-sized to 2" diameter 18" long glass-packs, and stock 2" tail pipes.
      1989 Ford Crown Victoria: Stock EFI 302, stock dual exhaust with 18" glass-packs.
        Hey,
        I guess here's my post. 302cid EFI lopo, with the upper 2 cats removed, but with the two 3-ways still intact with 18" cherry bomb glasspacks. '87 Tudor MGM LS.
        I posted it to my own web server since I didn't want it on youtube:
        (click on the link below, I used a freebie tool visible in the center watermark)
        http://pernonline.com/exh/Movie.html
        Mind you, I hadn't expected the loping after the initial idle. Also, the Canon digi-cam didn't pickup the full base sound - it really is a deeper booming sound.
        1987 Mercury Grand Marquis LS 2DR
        302CID, K&N air filter, Dual cherrybomb glasspacks, Vogue tyres (Front:P225/60R16,,Rear:P235/60R16), Centerline Pulsar wheels (Front:7", Rear 8")
        COBRA 25LTD CB with/ Wilson 500 whip antenna.
          here's my exhuast, she's dumped at the axle, stainless shorties, 2.5" BBK H-pipe with magnaflow hi-flow cats, and flowmaster super 44's. HO upper and TB with some other little mods make it bearable until some money comes in.
          It's quieter in the grass and allot deeper and punchy in person but this is how she sounds...the white smoke is just because its still a little nippy here, no coolent burnin haha.
          http://www.youtube.com/watch?v=5zgEuH6-DSU
            I took this one of the Lincoln last night. It was dark and thus nothing to see, but that's not the point, is it?
            http://www.youtube.com/watch?v=9wm65EwNUgY
                1971 Ford F-100, custom. 302. Dual 2.5 Flowmasters. 4-inch tailpipes.
                http://www.youtube.com/watch?v=PE85ouLtc24
                  91' EFI 5.0
                  stock manifolds, stock cats, custom 2.25" duals with H-pipe and magnaflow mufflers.
                  This is when it was new
                  This is after it broke in
                  Former panther owner
                  1981 CV 351 4bbl
                  1991 CV 302 EFI
                    95 mustang gt, bassani mufflers-
                    http://www.youtube.com/watch?v=nIC2ChY9kck
                      the new dual exhaust not fully complete but enough to drive down to scotts house and get it done.
                      Setup is walker cats, maremont h pipe, thrush welded mufflers, ap exhaust tailpipes and cherrybomb 22" exhaust tips with a 4" outlet.
                      http://s477.photobucket.com/albums/rr139/MattsGrandMarquis/?action=view&current=100_1250.mp4
                        this video is crappy, but- mac mufflers-
                        http://www.youtube.com/watch?v=XvgyT...eature=channel
                          http://www.youtube.com/watch?v=7S_nmfsHpaA Thrush 2 Chamber Welded Mufflers 2 1/4 Duals,H Pipe & Gutted Cats
                          sigpic351w .030, B303, 1.6 Roller Rockers, GT40P Heads Mild Port Job,351w Lightning Lower & Explorer Upper,65mm TB, Custom CAI, 24# Injectors, Adj FPR, 1/2 Phenolic Spacer, TPS Enhancer, Shift Kit, 2400 Stall, Hi-Rev Govenor, MMC Alcoa Driveshaft, 3.73 Trac Lok, Underdrive Pulleys, Electric Fan, MSD Street Fire Coil, MSD 6AL Ignition 12.35 @114 mph spinning through 1st gear
                            BBK headers, 2.5" header back, x-pipe, edelbrock RPM muffler.
                            Burnout, with nice idle before
                            revving
                            Autox internal cam-basically a drift vid.
                              http://www.youtube.com/watch?v=BvRk5aSf-vQ
                                here's my system fully finished and welded.
                                http://s477.photobucket.com/albums/r...t=100_1723.mp4
