86 mustang top end?
86 mustang top end?
- 2008 Mercury Grand Marquis Ultimate Edition - Daily driver - 4.6 2 valve Mod motor, 4R75E, 2.73s. Bone stockTags: None
no
86 ho intake is the exact same as the lopo upper intake
the 86 ho throttle body is only 55mm
86 ecm will work but you wont have no cruise control
86 mustang heads e6, same as what you got
oooh..I guess the ad was just worded poorly, I asked and the intake and TB are stock from his 93 coupe but he doesn't know what the stock TB size is. AWESOME.
thanks scottmangsigpic
oh, and I'm only doing the intake and TB. I need to do VC gaskets so I might as well put the intake and TB on while the old one(s) are off.sigpic
if a mod wanted to turn this into my HO intake/TB swap thread, feel free. I'd rather do that than clutter it up with another onesigpic
Make sure the date code on the upper begins with E
to be sure you are getting the 87 & up intake
Ok....100 bucks for the heads and cam also from a 93. I didn't really want to have my car out of commission for too long.
What do you think, all? I would still need the ecu and injectors (he has injectors but they're like 35lbs or something) so I wouldn't be done yet. 80 for upperstuff, 100 for heads and cam... Plus the $$$ for labor to put it all on.
I don't think I can justify the extra 2-3 bills and not having my car for a few days. I think I know what you guys are gonna say, buy what so you say?sigpic
- Oct 2009
- 2878
- Keene NH
- Send PM
DO IT! unless you are in a financial situation in which you can't atm (Like me) or see absolutely no need for it."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
I just have no idea what the ECU, injectors, and then the labor will ultimately cost me, hahasigpic
Originally posted by jayh View Postif you have to pay labor, using stock HO parts is pretty stupidsigpic
- Oct 2009
- 2878
- Keene NH
- Send PM
Originally posted by 1990LTD View PostIt's not like I would be going to a dealership to have this done. My mechanic works out of his own garage. If I were doing the full swap I'd probably help with most of it, I just don't know how to do it all myself.
On a side note if it is going to cost a lot of $$ in labor its not worth it in my opinion."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Swapping upper intakes, tb, and egr spacer takes all of 10 minutes. (Well at least if you've done it as many unfortunate times as I have).2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by 86VickyLX View PostThe '87 plus under the name badge says HO stamped in the casting of the plenum.
