5 speed swap
    5 speed swap
    Found a 5 speed for 175$. i think im gonna buy it. What else would i need? Slave cylinder, clutch, clutch pedal, flywheel....anything else??
    0
    No
    0%
    0
    Yes
    0%
    0
    Dan
    89_Grand_Marquis_351
    driveshaft might need to be made, speedo gear, shifter,
      the AOD and the manual arent the same length?
      Dan
        They are the same length.
        If you are putting this behind a 351 tho, you will need to get a special flywheel...
        Ill have to find you some info..
          I did say might, but mostly thats because i wasn't sure if the spline count on the output shafts were the same. Also wasn't sure they were the same size.
            What kind of 5spd did you find for $175? What was it out of?
            Tom
              how are you going to be driving the car? i've heard that the t5 doesent hold up to the heavier cars well when run hard............this came from the owner of the local speed shop, all he owns is fords......he said the tremec would be better suited for the car
                Im going to run a tremec
                  Make sure its a world class t5, the other kind is alot weaker.
