I've read places that you both can and cannot use GT40 heads on a stock 89 Towncar shortblock. I want to know the truth b/c i would like the extra 30hp from the GT's if at all possible. If I ran the HO cam as well would it be dangerous?
i want to run GT40 heads on my 89 towncar
get the HO cam and intake and computer, GT40 heads, headers, and youll be in business.
edit : there are 2 GT40 series heads i believe. the GT40P heads require special headers. someone correct me if im wrong
grand_marquis_gt: "Wow dude, you got the GMGT sedan!"
there, now im cool too
so the valves wont hit the pistons? this is kind of important i dont want to destroy my engine.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Lopo engines don't have valve reliefs in the pistons, but to my knowlege there is no clearance issue with using an HO cam with these pistons, at least with the standard e7 head. I don't know if the same holds true with gt40 heads and lopo pistons.
yes, there are 2 gt40 heads. gt40 use the same headers as the e7 or whatever. gt40p requires a special header that apparently only Ford makes. If you have the choice, i'd go regular gt40 just because you have a larger selection of exhaust that is known to work.86 Lincoln Town Car (Galactica).
it says in the HO conversion on Lincolns online that GT40 heads wont work because my pistons are not dished :bs: . but i want a 2nd opinion, has anyone put GT40's on a LoPo 5.0??1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
non ho pistons are dished.........as long as u use the ho cam and 1.6 rockers, you should be fine
or use clay or silly putty or something similar spread across the top of the piston.86 Lincoln Town Car (Galactica).
